Morning All,
The LSD on my Gen 2 Surf seems to have given/is giving up and not distributing torque evenly across the axle.
I've used the correct hypoid gear oil in it (with a friction modifier as it used to bind on tight corners without it.)
I have seen endless bearing kits for the rear axle, but so far no kits to rebuild the clutch packs or friction material inside the diff.
Does anyone have any info on rebuilding these?, who the manufacturer was (Torsen seems to come up a few times...), or know anyone that refurbishes LSDs (in the UK), not had any luck so far with the places I've called.
Cheers!
Will.
Cheers!
Will.
