I just had my lower front passenger side ball joint collapse as I was backing out of parking space. There was a big bang and the car collapsed on to the tyre , lucky I was going about 1mph. I managed to replace the joint OK but noticed the CV boot was ripped open somehow, I ordered a replacement.
I have removed the wheel and had expected it to be the same as a 2nd gen shaft , easy to remove. But this looks a lot more complicated, how easy is it to change? ?
When I removed my old 2gen shaft I just jacked up the suspension till the shaft was level ,undone the 6 bolts to the dif box , removed the hub cap and the shaft retainer , then the whole shaft just pulled out from the back with a little wobbling about. This looks totally different there is no 6 bolts and it's out. Or is it easier than it looks!!!
Das
Das
