Hello,
I (again) the problem that my rear windows can not be opened. The rear window is in the top position, but the window does not go on (down). When I press the switch on the console to close I hear clacking the relay, also is current on the cable that the engine goes on, but when press the switch to open the window, I hear no clack of Relay and no power is available at cables to the motor. Therefore, I think that my relay is broken! is that correct.
And now to my next question, you can bypass the relay, or open the window in a different way.
thank you
thank you
