I've got a P reg KZN185 with the allegedly "multi mode" 4wd system - generally seemed to work as expected until a few weeks ago when the dreaded flashing lights appeared on the dash.    I'd had a few stories from the previous owner about troubles which had taken a while for him to get sorted but as he wasn't the most mechanically minded of owners I'd sort of forgotten it.
So I've done the reading up on the very curious ADD system (http://www.off-road.com/trucks-4x4/t...tem-19259.html), but in this case I'm fairly sure that's working properly - rubber hoses ok, vacumn pressure is fine and it switches neatly when you swap the hoses over.
Next I go looking for the electric transfer case actuator. Find the entirely predictable error of breather hose split at the end on the actuator casing, and just enough water getting in to start to corrode the little contact rings and turn the grease white. Thankfully not totally shot.
I think I got lucky the first time I took the cover off - nothing awful fell out and I managed to clean things up well - reassembled easily enough and apparently worked well - for about a week.
Feeling bold I went back in again for a more thorough clean. Second time not so lucky - the magic spring mechanism which drives the pinion on the rack going into the gearbox has come forward just enough to move on the splines. So I've lost the critical rotary alignment between motor disc and selector shaft rack pinion.
I did try briefly to take the actuator off the gearbox for a proper strip down, but I've aborted that - there isn't enough clearance to really get it off and I don't fancy a transfer case strip to get the actuator rod out. It's gone back on the gearbox easily enough, and I can play with the little sprocket through the cover on the back of the actuator. What I need to do though is re-set or calibrate the actuator so the driven gear rotation matches the actual selector position.
I see several posts on here and other places (eg https://hiluxsurf.co.uk/node/83112) - some seem to get to a sort of solution, others are desparate pleas for parts (https://hiluxsurf.co.uk/node/83061) Most of the threads sort of die out without a conclusion.
I've found a load of Toyota docs on the web - mostly they seem to relate to a similar but slightly later actuator with an inline electrical connector rather than a square six-pin which is what I have. This adds slightly to the confusion as both have six pins but the numbering is different (motor on 1/2 rather than 2/3). There is an excellent Toyota training manual on the whole system which really explains the whole range of transfer gearbox systems (look for 13.pdf) but it is for that later connection and I think mine does just use it for 4wd/2wd - not to move the diff lock as well or range change which later versions of the same system do.
I had a chat with Frogs Island who I think fixed it for the previous owner. They remember the job, but not the critical "calibration procedure".
So - does anyone know the proper procedure? I know Toyota really just say "buy a new actuator - do not fiddle", but I get the feeling this has been done often enough that there is a real answer out there.
I am working towards trying the relay method listed in the Toyota docs for testing motion - then once I've got it at the end of the travel, trying to manually push it into either 2WD or 4WD positions checked with the limit switches then pop the little gear in, but there may well be a better way.
Whatever, assuming I do get to it I'd like to finish this writeup so there is actually a post with a definitive answer that doesn't fade out halfway.
Anyone been in here successfully?
