I wonder if folks know exactly what method is used to convert the speedo to mph from km/h??
In another thread that referred to it someone thought there was a sticker put over the speedo to show the correct reading.
Looking at this one all I can see is a small black sticker that has been put over the k of km/h. The speedo numbers go up to 160 which I assume was the max in km/h.
The dealer said something like "its all converted to read right, even the mileometer reading is corrected back to miles".
Must test it on the road but I can't see how it has been converted. Surely if the numbers are all still the same there must have been a gear changed somewhere in the speedo drive??
And what about the tyres fitted before it was sold...31x10.50 x 15. These look bigger than normal so will they affect how it reads if it has been set for standard (215x15?).
David
David
