Getting a bit warm! Bit of overheating!
  • #46
    Well after 5 weeks!!!!! Since the head went the end is in sight!!
    All being well and motivation being at above 30% the truck WILL be done tonight!
    I still need to drop the front and rear diffs I got as spares off to have them built with the lockers, 4.88's, and overhaul kits. But the truck will be mobile again with all the other bits installed.
    • #47
      She's alive!!
      Running sweet, just need to get the Diffs rebuilt, and the lockers in!
      • #48
        Originally posted by robjames View Post
        She's alive!!
        What lockers have you fitted?
        • #49
          Sorry for being so slow to get back on here! Works crazy and I rarely have time at the mo, one of the cons of being a 1 man band!!
          I went for the Spartan lockers and the Yukon ring and pinion gears and master rebuilds with solid spacer for the rear.
          I just need a spare few hours to run the diffs and bits to the diff specialist.
          But in other news the truck is running great since the head change and I'm taking every off roading day I can at the moment to enjoy it.
