Ok I'm either seriously unlucky! Or I must have been horrific is a previous life!!
Poodling about all day and temp gauge didn't move, however I touched the bonnet and thought it was warm!!! Opened it up and the expansion was bubbling away! ARSE!!
So I set off home disheartened!!! Cruising at under 40 no issues, if I go over 40 or go up a hill the temp gauge seems to rise above half way! Obviously I then slow down and the temp drops down!!
Now Ive read up and I cleaned the crap off the rad, checked the levels it needed a spot of water...........
Tried it again and it went over half way as I planted it going up the hill on the duel carriageway. But dropped down again when I was poodling!!!
So suggestions??
Rad appears to have a load of rad weld or similar in it to add to the story.........
Oh and I've added the winch to it today......
So suggestions??
