Rear diff
  • Rear diff
    Hi all
    I noticed a little oil on and around the pressure release valve on the rear diff, I think that's what it is. I undid the bolt on the rear diff to check the oil level, some oil dribbled out but there was a lot of hissing when I undid the bolt. Is it normal for this too happen? also how does the pressure build up?
    Any advice would be helpful.
    Mike
    Sounds like the breather is blocked to me
      thats right! you can extended it
      look here
      http://www.toyotasurf.asn.au/techsite/diffbreathers.htm
        I've got an extended diff beeather from mine in the garage if you want it.
          Thanks for your replies and help.
            Thanks for the offer. I made something up in the workshop and extended the breather.
            Mike
