ARB being a three letter word, acronym or whatever, doesn't show in the search function so apologies for starting a new thread.
My front ARB bushes squeak. I know it's them because if I spray them with WD40 the squeak stops, then reappears a couple of days later (in this hot weather anyway). Apart from being annoying it's costing more in WD40 than it would to replace them.
Now the question (finally, I hear you all roar in unison), how easy is it to change them? Do I need to remove the ARB completely or is it a matter of undoing the brackets that hold the bushes, taking the old ones off and replacing with new ones? Do the bushes have a split in them to allow you to fit around the bar or do they slide on from the ends? You may have guessed that I'm not a mechanic but I'm reasonably adept at doing mechanical wotsit things once I know how.
Any tips would be gratefully received as would links to threads where it's already been covered.
If you bothered to read this far thank you. If you didn't, f@&ck off you b&5t4rd5, you won't be reading this so you won't take offence.
