I have just become the proud owner of a 93 surf 2.4 diesel auto, had it checked over by a good mechanic who changed the oil and filter for me at the same time, underneath was bone dry at the time no leaks etc, after 700 miles on route to France I noticed oil seeping from somewhere near the autobox/rear of engine, all levels still ok and no lights on dash! It has now stopped leaking!! Has anyone any ideas??
LOST OIL, Where from??
Can come from the front dif but not at the back of the engine.
The other thing that normally fools most people is when the airconditioning has been on and has been switched off, water will drip down and you think that you have an oil leak.
Stick your finger in it and smell it, you'll know which it is then.If life's an uphill struggle then downhill from now on can't be that bad?!
Originally posted by richCan come from the front dif but not at the back of the engine.
Red/brown oil - diff , power steering , gearbox
Brown/black and thick oil and smells like cat pee - diff oil
My tips on oil ID
RickRick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
