Hi All,
Got a problem with my brakes that is not making sense to me...
Brakes are fine when the pedal is depressed and held, truck stops fine however, if the pedal is pumped then the brakes die away almost to the point of doing nothing and the truck does not want to stop, brake light (as in the handbrake light) flashes too. Pedal is fine in the first instance but when pumping the pedal it hardens up as it does when the engine is not running and the brake light on the dash flashes.
Fluid is good, was changed approx 6 months ago, this development is very recent. Pads, shoes discs & drums are all good nothing is binding, handbrake works fine and I don't appear to be loosing any fluid. All pipes look sound.
Anyone got any ideas?
Many thanks
Ben
Many thanks
Ben
