But if its seals, when you pump it hard like you do when coming to a junction and hold it there it will continue to sink.
You dont test master like servo, you test it either with engine off or on, then pump it hard and hold. It will fall half way to floor if 1 piston seal is gone and all the way if both.
Thanks, it doesn't do that. Will presume it is not seals!!
Spend some time, take all the vac pipes off, blow,through them, clean everything up and check for perishing or leaks.
Also remove and resurface the pads, I had an issue not too long ago with newish pads, they glazed over, were crap, pedal went hard then locked the front left wheel everytime. Might help.
Cool, will have a dig about on Sunday when I do a fluid change.
