lost oil in gearbox
  • lost oil in gearbox
    need help coming back from lakes yesterday and suddenly,smoke came piling out of back end of car . pulled over to see and found auto transmission oil dripping out of bell housing onto exhaust not too long after i lost drive and my gearbox was empty? how did it go so fast ????
    Broken oil cooler line,mainshaft pump seal, loose dipstick tube really need to topup and check.
      Originally posted by Diezel Weazel
      Think you'll find its the inhibitor switch on ya Gearbox (allowing ATF to be sucked into the inlet n out through the Exhaust)
      info here....
      http://www.hiluxsurf.co.uk/showthrea...hibitor+switch
      Good Luck
      11+ Years of Surfs ..... n Faultless to a "T" is my Yota !!
      How when oil is dripping out of bellhousing?
        info here....
        Good Luck
        HUH!
          Absinth and Magic Mushrooms again?
          www.johnthebuilder.info
            note to self !! must read post properly
            Thanks Chaps
            Buncefield Burner
              hi and thanks all i had similar trouble when i changed engines and found i had damaged oil seal on main shaft of gearbox cant remember it draining so fast though ??? also oil very black was told my clutch packs are goosed ???
                Sure sign clutch packs goosed
