need help coming back from lakes yesterday and suddenly,smoke came piling out of back end of car . pulled over to see and found auto transmission oil dripping out of bell housing onto exhaust not too long after i lost drive and my gearbox was empty? how did it go so fast ????
lost oil in gearbox
How when oil is dripping out of bellhousing?Originally posted by Diezel WeazelThink you'll find its the inhibitor switch on ya Gearbox (allowing ATF to be sucked into the inlet n out through the Exhaust)
info here....
http://www.hiluxsurf.co.uk/showthrea...hibitor+switch
Good Luck
11+ Years of Surfs ..... n Faultless to a "T" is my Yota !!
HUH!Originally posted by Diezel WeazelThink you'll find its the inhibitor switch on ya Gearbox (allowing ATF to be sucked into the inlet n out through the Exhaust)
info here....
Good Luck
Nev
Sure sign clutch packs goosedOriginally posted by bluesurfman123 View Posthi and thanks all i had similar trouble when i changed engines and found i had damaged oil seal on main shaft of gearbox cant remember it draining so fast though ??? also oil very black was told my clutch packs are goosed ???
note to self !! must read post properly
