Has anyone any idea's why I can't get my gearbox into low range? I’ve got a 2.4 auto and although it had a large suspension lift (see on members rigs) I see no reason why I can't get it into low range. 4 wheel drives engages o.k. but when I’m putting it in low range I can't get the gear stick past neutral without it crunching gears.
Gear box problems
You are only moving it with the motor stationary aren't you. The transfer box does not have synchro hubs and the vehicle cannot be moving. If you have an Auto it must also be in Neutral (Not Park).Originally posted by PBRADYHas anyone any idea's why I can't get my gearbox into low range? I’ve got a 2.4 auto and although it had a large suspension lift (see on members rigs) I see no reason why I can't get it into low range. 4 wheel drives engages o.k. but when I’m putting it in low range I can't get the gear stick past neutral without it crunching gears.
I also believe that due to the lift the lever is fouling some where and not allowing its full travel to allow you to select it.Originally posted by luckyYou are only moving it with the motor stationary aren't you. The transfer box does not have synchro hubs and the vehicle cannot be moving. If you have an Auto it must also be in Neutral (Not Park).
I think the stick has to be altered with a slight offset/extension to allow operation once somethings been lifted over a certain amount, TonyN should be able to confirm this more.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
