Ive noticed that this panel is a bit loose and the seal is broken. Obviously water is likely to get in but Im not sure if there should be a gasket or rubber seal here
or its just a silicon job? Also does anybody know the best way to remove this, and repair it. Can I just undo the spare mount or do I have to strip the tailgate out for access?
