Oil and filter change
  • Oil and filter change
    I normally do these my self but this will be the first time on a surf and just wondering if its a case of undo filter and put new one in its place?
    Originally posted by Thrifty
    yes access it from the side under the wheel arch not from the top of the engine. if you catch the filter in a 2 ltr coke bottle cut in half it will be less messy.
      ..now you tell me
      Did my first change today, oil, fuel and air, feel like a proper man now haha.
      Yes catch that oil and don't over tighten the oil filter was advice passed to me
      9/11 WAS AN INSIDE JOB!
        Originally posted by spacast View Post
          I must agree with albanach, quotes like that from thrifty are total nonsense! The oil filter is better accessed from the top (3ltr), most of the oil would have drained back into the sump. Once the filter is loosened with your filter wrench the residual oil runs down a small tube to just above the front axle put a bowl under that to catch it.
