Hi, i'm gonna change my track rods. Is it just a case of cracking both balljoints either side of the rod and replacing with the new one?
Track Rod Replacement
 No.Originally posted by Don Logan View PostHi, i'm gonna change my track rods. Is it just a case of cracking both balljoints either side of the rod and replacing with the new one?
 Yes, different sizes and types.Originally posted by Don Logan View PostAnd do bj splitters come in certain sizes? My cousin said he's got one but is unsure whether it's the right size for track rod bjs.Do you know that, with a 50 character limit, it's
 No worries. Remember, you asked a closed question; I answered it concisely.Originally posted by Don Logan View PostWow, thanks for that. Bullied at school? Neglected by mother as a child perhaps?
 I was never bullied as a child, but I was put up for adoption. Does that constitute neglect?
 The easiest way to do it is to loosen the pinch nut or bolt on the rod end, then split it from the hub. Once split, count the number of turns it takes to screw the rod end off, then re-fit the new one by the same number of turns. Not an exact science, but certainly close enough to get them done and get the truck to have the wheel alignment adjusted properly.Originally posted by Don Logan View PostWould anyone care to give me a brief description explaining how to change my track rods?Do you know that, with a 50 character limit, it's
 Another way to do it is to keep the truck on the ground, remove the old TRE and screw the new one on so that it easily slips into the steering arm without moving anything. Again, only good enough to do the job and take it to get the alignment set up properly.Do you know that, with a 50 character limit, it's
 Thanks, i'm changing the whole rod though, not just the end. I get the outer end bit, but do i just do the same for the inner end in terms of loosening the castle nut and popping the BJ?
 http://farm7.static.flickr.com/6164/...dd9f33ec63.jpg
 If not, then:
 Could someone please give me a brief description of how to change the inner tie rod end?
 Thanks.
 What exactly is it you're changng? The bit that's loose in that picture is the BJ on the pitman arm.Originally posted by Don Logan View PostThanks, i'm changing the whole rod though, not just the end. I get the outer end bit, but do i just do the same for the inner end in terms of loosening the castle nut and popping the BJ?
 If not, then:
 Thanks.Do you know that, with a 50 character limit, it's
 Take the old ones off and lay them on the floor, build up the new set (making sure both TREs go into the centre bit by the same ammount). Lay the new set up on top of the old one and adjust to the same length using the centre bit (so that both ends move the same ammount). Then just re-fit.Originally posted by Don Logan View PostThe track rods. In their entirety; Both ends. Middle bit that turns. Clamps. The current ones are seized.
 It doesn't matter how exact you are with the measuring, you'll need to get the tracking done once you've changed them.Do you know that, with a 50 character limit, it's
