Rear diff on a '92 Surf. Metal was found during an oil change apparently. This piece of metal looks just like a sliver from the Case Sub Assy from what looks like the pinion has moved back into the diff. The piece of metal has the lines in it, which match the lines from machining on the case assy. Looked at a couple of other dead diffs that have been removed and dismantled and saw these machining marks. Now the question is if we replace the front pinion bearing, seal and crush sleeve, torque it to specs, do you think this will be a fix that will last a while and hopefully stop the pinion from moving back in the diff.
Nev
Nev
