Originally posted by Big_ben
View Post
Speedo problems - affecting gear changes?
It could just be a dead speedo head inside the gauge itself, I've had a Honda cluster do that on me. I would test the wires at the back of the cluster for a speedo signal (maybe with the rear wheels on jackstands, front wheels chocked kind of thing), and if there is signal to the cluster, swap clusters and see if that does it. If there is no signal to the back of the cluster, then you have a broken wire somewhere between the VSS and the cluster.'96 Toyota Hilux Surf SSR-G - RIP
IanB2..thanks for the info. Probably sounds stupid...but I am not sure how to check signals at back of speedo. There are four multi pin connections - which is for speedo/odometer? Also....how do I actually check?? Sorry if thats a stupid question...
Bushwacker.....had another think about when I checked the signal from VSS......and I am unsure now. In the diagnostics port there is a VS1 and VS2. Which is the VSS??? Regardless of whether rear drivers wheel is turning or not....VS1 has a constant 11.89v coming from it and I get nothing from VS2.
Any thoughts. Any help much appreciated.92 Manual, 93 auto, 03 Dual Cab, 95 Single Cab
Checked the fault codes......I am getting 1 single flash with 4-5 seconds between each flash. I think this means that there are no faults....... And hence....my VSS should be working....and hence it is most likely the speedo cluster that's not working??? Is that logical....?
Removed cluster again today....couldn't see any obvious breaks in the tracks or anything. Is the next best step going to be trying another cluster?92 Manual, 93 auto, 03 Dual Cab, 95 Single Cab
If you can find another cluster to try, this would be easiest. I don't have the cluster pinouts with me, but I think I have them at home. I found a site that had a bunch of stuff like that, and printed them all off for my cruise control installer (wasn't sure if he'd need that stuff, but wanted to have it available).Originally posted by Big_ben View PostRemoved cluster again today....couldn't see any obvious breaks in the tracks or anything. Is the next best step going to be trying another cluster?'96 Toyota Hilux Surf SSR-G - RIP
