Hi all,
First time poster here. I've had too Hilux's previously - '95 Mk3 single cab and a Mk5 double cab.
In the last 2 weeks I've bought a 1993 SSR-X Surf (Jap import 2.4). A few problems - (unfortunately one of them is overheating...I KNOW!....but I will post more about that after I hae had time to check a few of the basics.)
The other problem is the lack of any movement in the speedo and odometer. It doesn't move at all. I have done a bit of reading on this...and a lot of people are pointing towards the VSS or speedsensor. Where is this located on the gearbox...how would I identify it? (Haven't gotten my Hayne's manual yet!!!!)
Is there any chance that it's only a loose cable at the back of the speedo - and not a new sensor?? Also - does the VSS feed back to the ECU for gear changes? I reckoned that it was revving a bit too high before changing gears - but it's my first auto box so I'm not sure. Also - if that is the case that it's revving too high - would that rule out the loose cable at back of speedo?
I know there is probably a lot of questions in that post - but any advice would be much appreciated.
Regards,
Ben
Regards,
Ben
