The needle on my speedo gauge always sits about 10 MPH when the vehicle is not going. When I am driving it it fluctuates beteen 20 ~ 30 MPH even though I know I am doing over that speed. When I then stop speedo stays at this mark. If I then bang the top of the dash with my fist (not a violent person honest) it drops back to 10 MPH. Any ideas what is causing this before I start ripping things apart. Is it most likely to be the actual speedo or could it be the sensor from gear box ?
Speedo sticking
Originally posted by BUZZThe needle on my speedo gauge always sits about 10 MPH when the vehicle is not going. When I am driving it it fluctuates beteen 20 ~ 30 MPH even though I know I am doing over that speed. When I then stop speedo stays at this mark. If I then bang the top of the dash with my fist (not a violent person honest) it drops back to 10 MPH. Any ideas what is causing this before I start ripping things apart. Is it most likely to be the actual speedo or could it be the sensor from gear box ?
Is it the original Kph gauge, or a replacement Mph one? If its a replacement one porr fit or fitting could cause interference with the needle resulting in symptoms such as you describe.Maurice
Always been like this since getting it so I don't know if its original Kph gauge or a replacement Mph one. Looks like it could be poor fitting, problably best if I dismantle dash and have a look - doesn't really bother me but I suppose the "Bottles and Stoppers" would view it differently...
Originally posted by BUZZAlways been like this since getting it so I don't know if its original Kph gauge or a replacement Mph one. Looks like it could be poor fitting, problably best if I dismantle dash and have a look - doesn't really bother me but I suppose the "Bottles and Stoppers" would view it differently...Maurice
sticking speedo
Had my surf ssrx transferred from kmph to mph. and the garage fitted a mechanical convertor (whatever that is) Recently had the car and I love it. Problem is the garage who did it for me has gone bust and my speedo goes up to 40mph and stays there even though I'm doing around 70mph. When I slow down and stop the needle comes down normally back to zero. being a thick plumber can any of you guys help on this.
Jamie
Originally posted by yungjamieHad my surf ssrx transferred from kmph to mph. and the garage fitted a mechanical convertor (whatever that is) Recently had the car and I love it. Problem is the garage who did it for me has gone bust and my speedo goes up to 40mph and stays there even though I'm doing around 70mph. When I slow down and stop the needle comes down normally back to zero. being a thick plumber can any of you guys help on this.
Jamie
Did it initially work OK?
Did they also change the face (ie does it now have mph printed on it rather than the original kph)?
Even though the needle fails to rise properly, is the odometer continuing to count up correctly?
Any chance of a clue as to what year of a Surf we're refering to?
If you put your vehicle details into your profile, they will show up on the left, this will help ensure you recieve assistance most relevant to your particular vehicle.Maurice
I would assume as a mechanical convertor was used, it would have been fitted via the gearbox and would say you have a 2LT (don't think you can fit them on the 2LTE as its electronic). I would get the convertor checked, the are relatively cheap things, may be its not fitted correctly or come loose.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
stickin speedo
I don't know if the speedo was working okay in kmph as the garage picked it up for me which I bought at auction and they did the conversion. The speedo now says mph. It goes up to 40mph and then stops there. It comes down okay from 40 to zero. One thing, the speedo is stuck on 69,999. The trip digit works okay. My car is a 93 ssrx 2.4. Love her to bits but it's just the problem with the speedo.
Jamie
