Hi folks,
Wonder if any of you might be able to help with this..
Ive been hearing a grinding noise from the front left axel. Initially I thought it was the wheel bearing but investigation has proven it to be fine..
I have taken the disk and wheel hub off and found that turning the stub axel as it sits causes the grinding sound but if I take the weight of the stub axel and then turn it the grinding doesnt happen....
I´ve never taken the apart more than the disk, wheel hub etc so not sure what I will find or what the problem might be...
Any suggestions would be greatly appreciated.
Thanks
Thanks
