My, 93 2.4 Surf (LN120) has just lost it's speedo and odometer, the Overdrive Light has also started to flash. What can I do to fix this and is it still Ok to drive. Please can some one help
Help Urgent
Originally posted by scubaman View PostMy, 93 2.4 Surf (LN120) has just lost it's speedo and odometer, the Overdrive Light has also started to flash. What can I do to fix this and is it still Ok to drive. Please can some one help
My guess is that it's the speed sensor, or the speedo head; mine was a burned out track on the speedo PCB.Last edited by Albannach; 22 October 2010, 20:42. Reason: Sarcasm added, then removed, then edited again and finally removed.Do you know that, with a 50 character limit, it's
