2" Suspension lift kit help
  • 2" Suspension lift kit help
    The slow ass garage who have been repairing my Surf (6 months now)following the accident are taking their sweet merry time to get everything finalised and I've had enough. I bought the 2" kit from Roughtrax and now feel that the only way this is ever going to get done is by doing it myself. How easy a job is it and will I need any special tools? I'm no mechanic, but I have just replaced the shocks and water pump on my Cherokee and put a new starter motor on a 200Tdi converted 1988 Land Rover 110. That's more or less the level I'm at.
    Should I just wait until the garage get round to doing it or is it a piece of p155 to do and I should do it myself?
    If you have done shocks etc on other trucks then you will be able to do the suspension lift on thesurf.I would get some spring compressors tho to help with the removal and fitting
      Cheers Stormy, didn't really think it'd be too difficult, just never done springs before. Sods law though, all my old man's mechanic tools I inherited when he popped his clogs are sitting in a garage in the uk and I know there's some spring clamps in that lot.
        Just found some on ebaay, delivered for 20 quid, that'll do me.
          give yourself 3 hours and you'll be done or maybe 4 hours with tea breaks
            hi sorry to butt in but i was thinking about doing the 2" lift on my truck. but did read something somewhere about the lift messing with the gearing is this true??
            thanks
              thanks
              Gearing is only affected by size of your wheels/diff ratios or gear box ratios... not the distance of your body off the ground.
              If you mean with regard to CV joint wear, then yes, increasing angles of CV joints will inevitably lead to greater wear.
              HTH
              www.johnthebuilder.info
                Four, 2" lift springs for a 3rd gen Surf, delivered for £20?????
                Is that an R/C model Surf?
                  i think he meant a set of spring compessors for £20 delivered lol
                    Exactly!!! HOWEVER, be careful which type you buy. My old man's ones had a curved grippy bit at each end and the ones I bought have more of a 45deg angle. The problem with this is that you can't get them really tight and secure, as I found out when it slipped off whilst compressed - I was lucky not to have lost all my teeth. As it was it flew off and slammed into my bicep and cut it open. Kind of made me a bit wary now and all the bits are still in their boxes waiting to be fitted.
                    Anyone coming to Spain any time soon and want a fitting job? Can accommodate!
                      Use a pair of compressors to compress each spring as much as possible and tie them with sash cord or similar then remove compressors.
                      Fit springs to rear axle, lower truck the the ground so the weight is on the springs, then cut the cords.
                      Repeat method for the other springs.
                        I'm in the process of getting everything ready to do this job (not tonight).
                        That's a great idea there.
                        Lift one spring out and instantly slot the other in!
                        I hope my knots hold
                          Anyone have any ideas on the best way to tackle the fronts? I'm finding that the space is so restricted that I can't get the shock and spring in place with the clamps in situ.
                            Thats probably the reason Bushy said to tie the springs with sash cord or similar, I reckon those small ratchet straps with webbing would do a good job of this too. H
                              I have been trying the cord idea but I just don't seem to be getting sufficient compression on the springs to enable me to refit them. Went and bought a set of "claw" type clamps today as the cheap ones I bought off ebay are one of the most dangerous tools I've ever used.
                              Where I do now seem to having a bit of luck is clamping them first, then tie them up, then re-clamp for some more compression, then shoving something solid in the newly created slack of the cord. Hopefully this will now fit and when in situ I can cut the cord and my "wedge" will just fall to the floor - in theory.
                              The ratchet strap idea is brilliant, I'll also be giving that a go, although I'm not sure they'll be strong enough to compress these springs, they really are stiff.
                              Any other tips would be greatly appreciated.
