newbie Surf owner
  • newbie Surf owner
    Hello all,
    we bought a '96 3rd Gen Surf a few weeks ago and have a small problem I'd like to solve asap.
    the steering wheel is wobbling pretty badly under braking which I assume to be warped discs ? (could it be anything else ??)
    my questions are:-
    are the front discs from Roughtrax of a high quality and would you recommend genuine toyota pads over the non-OEM versions offered by Roughtrax as part of the front brake kit they do ?
    also, please can anyone tell me the wheel nut torque ?
    thanks,
    nick
    Originally posted by nickhudson View Post
    Hello all,
    Most likely cause, had this on my previous Surf, changed discs and pads and no more wobbling steering under braking
    my questions are:-
    Got mine from here seemed ok but sold the Surf a few months after fitting so not really got a good feel for them.
    As for brake pads I now have a 4Runner and have fitted EBC pads. Best ever no more brake fade and less dust from them and what there is just cleans off easy. Not sure if they do a fitting for the 3rd Gen
    thanks,
    nick
    My 4x4
    My choice
    Back off
      Hi newbie, as Koi says its most likely warped discs but also check that the front tyres are ballanced correctly.
      The R-trax discs & pads are spot on, i put a set on mine last year & ive had no problems at all + i checked them a few weeks back & there is still plenty of meat on the pads even after 20,000 miles.
      You will have to use the search facility to get the torque settings but most on here just tighten them as they would on any other car/4x4.
        thanks all,
        eventually went for the R-Trax discs and genuine Toyota pads - problem solved
        i always prefer to tighten wheel nuts/bolts to a specific torque having made sure the threads are clean - i am an Engineer and the thought of guessing nut torques on wheels is not something i'm happy with - i will search around for a figure
          113 N m
