Hi all,
I've been getting a rattling/metalic clonking noise when under load. Doesn't seem to do it unless using accelerator. I've done a bit of research on here and sounded like bronze bushes needed replacing.
I took it to my local garage to get it checked out and said no play in front hub area but play in steering idler, inner track rod and rear prop UJ.
My steering has seemed fine but can any of these items be causing the noise I've been getting. Going to get them all done anyway but I don't want to do all that and then still have same problem.
Thanks
Thanks
