power steering pump help
  • power steering pump help
    Hi guys any help would be massively appreciated,
    The power steering pump pully has worked its way loose some how, which i can not see,the nut is still on the shaft but the pully spins very freely to the shaft of pump,if that makes sence.
    anyway im trying to remove the pump but its a total pig,there is a bolt in top of pump that holds it on that is too long,and hits the pully wheel, im lost and need help
    Not going to rest till its broke
    Either cut the bolt as in other thread or use a thin cutting wheel on a grinder. Only other thing I can think of is to weld a bar on the end of the shaft so you can undo the pulley bolt, then grind the bar off.
    Can you get a nut splitter on the pulley bolt ?
      was hopeing not to go down that route but looks like only way,cheers mate
        I might have a replacement power steering pump for a 2.4 if you need it.£50 delivered for you
          cheers stormforce, but sweat grit and pig ignorance i managed to get the thing off,and pump looks good,just need a new pin and bolt,but cheers anyway
            no worries mate.If i can help with anything then just give a shout
