Hi guys any help would be massively appreciated,
The power steering pump pully has worked its way loose some how, which i can not see,the nut is still on the shaft but the pully spins very freely to the shaft of pump,if that makes sence.
anyway im trying to remove the pump but its a total pig,there is a bolt in top of pump that holds it on that is too long,and hits the pully wheel, im lost and need help
