hi i need help! i hit my ariel off an out branch and it bent it to a degree that it broke off! can anyone please tell me how difficult it is to replace? when i switch my radio on there is a grinding noise that lasts around 15 seconds then stops, presumably trying to put up the top 2 3rd's of ariel that is no longer there, and the last thickest (bottom) part is stuck inside and refuses to budge. any advice greatly appreciated. Thanks!
replacingthe radio aeriel
from memory
remove top of mount from the aerial, switch on aerial which should out the aerial and platic toothed strip.
Gently feed new plastic toothed strip in until it stops. Get a friend to switch of the radio and then gently feed plastic strip in followed by the mast.
Replace the top mount job done.
There should be instructions with the replacement mast on how to do it.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
