replacingthe radio aeriel
  • replacingthe radio aeriel
    hi i need help! i hit my ariel off an out branch and it bent it to a degree that it broke off! can anyone please tell me how difficult it is to replace? when i switch my radio on there is a grinding noise that lasts around 15 seconds then stops, presumably trying to put up the top 2 3rd's of ariel that is no longer there, and the last thickest (bottom) part is stuck inside and refuses to budge. any advice greatly appreciated. Thanks!
    from memory
    remove top of mount from the aerial, switch on aerial which should out the aerial and platic toothed strip.
    Gently feed new plastic toothed strip in until it stops. Get a friend to switch of the radio and then gently feed plastic strip in followed by the mast.
    Replace the top mount job done.
    There should be instructions with the replacement mast on how to do it.
    My 4x4
    My choice
    Back off
      when i did this a bit of the strip got stuck in the mechanism and would not come out so i had to remove the motor open it up and get all the bits out fairly easy job. but try the easy option first.
        Did you take the wing off to get at the mechanism or just go in through the wheel arch?
        Cheers.
          there must be some way of switching the aral so it gos down and you can still have the Cd i never listen to the radio when off roading
          S S R G is the only way to surf
          scottish mud club member kerelawsurf
            my arial does not come up when my cd player is on. it might br the head unit you have
            SWIFT AND BOLD
