Who's Good at diagnosing Noises from a surf???
  • Who's Good at diagnosing Noises from a surf???
    i have a strange noise coming from around the passenger footwell underneath.
    sounds like hammer drill, into soft stones..... and it varies with speed, in 2wd its very bad but eases off in 4wd....
    and steering lock is alot less now than it was.....
    I would Hazard a guess at the drive shaft,? or associated parts.
    www.furryfriendsinneed.com
      my line of think as well, i lay under it last nite and gently wiggled anything i could grab but no play ah well.... this is not something i think i'll be able to diagnose, i think its off to my favorite Lithuanian mechanic Rokas....
        You can try jacking up the front passenger side, and see if there is alot of movement in the wheel, bearings etc,
          Take the jack out of its cubby hole, see if that helps.
            JACK: : :
              Search for 'bronze bushes'.
                He can't even find the jack!
                  dont drive on the verges
                  I NEEED MUD.....and Welsh spring water!!!
                      Hey matt i have a bad rattle in my surf as well i found what it was though "your bl00dy tool box"
                        my jack wont reach the chassis i will search bronze bushes.....
                            That's not what I said to do.
                              put the jack under the front cross member then jack then jack the front up
