Delboy,
the rack isn't that heavy (all aluminium), and its supported on the internal roof braces packed tight to the roof skin. No movement even when I stand on it... It should take upto 200kg at a comfortable push.
Peli Cases have arrived and look double sexy up there.
Snorkel... model number is SS105HF..
Remember, measure three times cut once... Concentrate on the job... (not like I did and cut the outside hole the size the inner hole should have been) Looks a bit dodgy very close up... but works fine. You'll need a cut off saw to remove the inner wheel arch brace. Local Stereo place let me use their air tools to make the holes (much to their amusement)...
andyL
andyL
