Currently got the timing cover off as have just done the crank oil seal. Waiting for new timing cover seal to turn up so have a spare day.
Is there any reason not to remove the air con pump ? - I removed the radiator for it last year when I did the head. Means 1 less belt to worry about and easy access to the alt if it has any probs ?
Something in the back of my mind is saying 'loads on pulley changes' but I think I may be making things up
Cheers,
Rob.
Cheers,
Rob.
