After putting my manual surf into 4wd in the high box (and possibley low box) and then disengaging 4WD I can hear a whurring or whining noise (hard to describe it properly - sounds a bit like a sticky clutch release bearing) but its only after coming out of 4WD so I don't think its clutch related. If I stop the surf and then start it again then the noise is gone. Any ideas?
Noise after 4WD is disengaged
Sounds like either the ADD actuator or ADD solenoid is sticking.
Have a look at this document, it has all the relevant bits.
Rich.
http://www.afm15.dial.pipex.com/surf...l%20system.pdf
Originally posted by BUZZAfter putting my manual surf into 4wd in the high box (and possibley low box) and then disengaging 4WD I can hear a whurring or whining noise (hard to describe it properly - sounds a bit like a sticky clutch release bearing) but its only after coming out of 4WD so I don't think its clutch related. If I stop the surf and then start it again then the noise is gone. Any ideas?If life's an uphill struggle then downhill from now on can't be that bad?!
