Noise after 4WD is disengaged
  • Noise after 4WD is disengaged
    After putting my manual surf into 4wd in the high box (and possibley low box) and then disengaging 4WD I can hear a whurring or whining noise (hard to describe it properly - sounds a bit like a sticky clutch release bearing) but its only after coming out of 4WD so I don't think its clutch related. If I stop the surf and then start it again then the noise is gone. Any ideas?
    Sounds like either the ADD actuator or ADD solenoid is sticking.
    Have a look at this document, it has all the relevant bits.
    Rich.
    http://www.afm15.dial.pipex.com/surf...l%20system.pdf
