3rd gen 4wd :(
  • 3rd gen 4wd :(
    So....fitted my diff breathers and have managed to lose my 4wd.
    When trying to put a front breather on, I was running my hand all round the front diff and transfer case.
    It is a 3rd gen (albeit the very early one (or potentially an american style one) that doesn't have "multi-mode" 4wd).
    When I press the 4wd button on the transfer lever, nothing happens...no light, no 4wd, no nothing.
    I don't know where the relay is (and in the past, when it was working and selected I never heard a relay clicking on).
    I have checked the a.d.d hoses and they are all connected top and bottom.
    I have had the hoses off the solenoids and I am getting "suction" on some of them.
    When I am under the car, no matter where the lever or switches are the front prop-shaft can be spun by hand.
    I have disconnected and cleaned every plug on the transfer case I could find and re-connected it.
    It drives etc fine in 2wd.........but I wanted a 4wd so I could get it muddy.
    Anyone any ideas?
    If there is an a.d.d. sensor or switch on the front diff....if there was a problem with this would it give these symptoms?
    I am hoping it is something simple.........as it was simple to cock up
    Any thoughts anyone?...something simple?
      Check the connections on the front diff - there should be a couple there, smaller one for the 4WD light on the dash, the other (on the back I think) is for the motor to engage the sleeve that connects the diff (simple terms).
      Just make sure everything that looks like it should be connected is.
        What I thought.........and what Mudsurfer said (thanks matey)...
        ..plug on passenger side of front diff that follows the breathers up.....just had a fiddle around with it and got back in the truck and the green light came on.
        .....as I had the car up on axle stands I even checked it was working (lifted one front wheel and one back wheel....stuck it in drive then engaged 4wd and the front span as well as the back...
        Happy I am
        when I get the time, I'll re-wire the plugs and waterproof it all, it all looks a little exposed.
