If the hubs are locked the front shafts should turn when the wheels turn. Unlocked they will not. Check this before pulling everything apart. If all is ok then your problem is with the ADD or transfer case.
Assuming it's actually in 4wd. He doesn't seem to know what that is!
Do what Nev said. Another way of checking is to unlock them and try to turn the front drive shafts by hand, if they turn, you know the hubs are unlocked. Then go lock them and try again. If they don't turn, they're locked.
Another Edit: Assuming the truck is in 2wd!
i have a noob question if i may.
what do people put locking hubs on for? what do they do?
It allows the wheels to spin without the front shafts, diff and driveshaft to spin.
In the surf when the transfer case is not engaged the front drivetrain will still all turn, but is being turned by the wheels not by the driveshaft.
With the hubs unlocked, just the wheels turn, saving a bit of wear and potentially a bit of performance/mpg.
Also, you "could" weld up your front diff (so that it behaves like a locked diff or a solid axle) and then when you lock your hubs you are effectively getting proper diff-locked wheels (i.e. they behave like a spool and both will rotate at the same speed even if one airborne).
Potentially the cheapest way to get a locking/unlocking axle.
