hi been checking the surf and found that the coolant level is near the low marker on the expansion tank, that was when the engine was cold,when should i check the level when its hot or cold???.also should i fill it via the cap for the rad or should i fill the expan tank???
also i beleave that the jack is under the rear seats is that correct if so how do i get the rear seats up??
cheers all!
cheers all!
