I was driving down the road the other day, luckily just quite slowly about 30mph at a guess as i have no speedo. I though i had suffered a blow out as the truck dropped on the drivers side and pulled over to the right, i had to steer quite sharplu left to avoid the oncoming double decker bus. I pulled over and got out to check my tyre to find it fully inflated and the truck jus leaning slightly to the right. On inspection i saw that the top wishbone has torn out of the bracket this bracket is welded to the chasis and also holds the shock and engine mount i think. My question is ......Can these bracket be brought or is it a cut off a donar chasis and weld onto mine sort of job? Pictures to follow in bout half an hour once ive installed the phones software.
many thanx yet agen
many thanx yet agen
