Been told i need to flush out any trace of old engine oil before putting a new turbo as any pooh left inside could wreck it.....my question is how the chuff do you flush an engine without stripping it ? bear in mind i cannot fire it up, it has no manifold on....also how do you turn a diesel over with out it bursting into life, can't just pull the dizzy cap off can i ????
To release compression could pull heater plugs would that work?
Thought maybe whip off the rocker cover and sloush some petrol about and let it drain down into the sump, spin it on the key a bit then drain the sump....any petrol left will evaporate or combust in me bottom end oh er missus.....is this a bad idea ????
Paul1566
Paul1566
