ive been running the tank low to see what sort of mileage im getting, and have been getting pretty low, have not had any warning light come up,, is there one. ??
low fuel warning light - have i got one
if it is like mine it is a rectangle by the empty end of the gauge and apears to be on a rheostat? gets brighter as you have more likelyhood of running out, nose up is brighter on mine and about 15 miles when lit - however if I go uphill when it is that low I have starved the motor to standstill!!!!!!!! carry a can if you intend to test it and make sure you know how to manualy pump on the filter and even bleed the injectorsDid I mention I have a BLUE one
Tony
low fuel
Ratfires is spot-on. Uphill = bright light, downhill = dims or out if not too low.
I've run-out a couple of times. 20 or so miles I reckon. No big panic if you have a can as the system will bleed without disconnecting anything (unlike some!)Yes! It's still in the garage. M1ROD
'Kin-ell I got some thing right for a change....first time I been called Ratfires tho!Originally posted by Trooper View PostRatfires is spot-on. Uphill = bright light, downhill = dims or out if not too low.
I'm fat and I do Fires!Did I mention I have a BLUE one
Tony
Ah i see, my supra fuel light works the same, dim light at first. think ill get a can and see, i assume if i run out i prime it using the fuel filter thing in the engine bay, give it a pump till fuel comes through.Originally posted by fatfires View Postif it is like mine it is a rectangle by the empty end of the gauge and apears to be on a rheostat? gets brighter as you have more likelyhood of running out, nose up is brighter on mine and about 15 miles when lit - however if I go uphill when it is that low I have starved the motor to standstill!!!!!!!! carry a can if you intend to test it and make sure you know how to manualy pump on the filter and even bleed the injectors
worked for me......as did, going uphill, engine spluttered, uturn quick - fuel to engine again, uturn, over hill garage downhill from there...if anyone had been around they would have thought I was crazy, but it was typical devon weather - liquid sunshineOriginally posted by Fargo View PostAh i see, my supra fuel light works the same, dim light at first. think ill get a can and see, i assume if i run out i prime it using the fuel filter thing in the engine bay, give it a pump till fuel comes through.
Tony
Me too actually
This very week I saw it for first time (after Three years ownership)
it was low, i knew that but waiting to join the road, and parked on a fierce incline facing upwards,
theres a vertical bar of orange light on the 'E' side of the gauge
