I've finally removed my master cylinder to swap it for a new 2nd hand one.
Unfortunately, as I left it so long to fit the replacement, the new one has gone quite rusty on the end where the circlip and piston arrangement sit.
I've taken the piston/plunger assembly out of mine and it appears to be fine, the rubber seals are in good condition, everythings spotlessly clean etc.
So, should I fit my piston assembly into the new cylinder or just reasemble mine.
Is there anything else that can go wrong with them other than the rubber seals going?
Chris
Chris
