Wheel offset
  • Wheel offset
    Hi all
    Stupid question no. 312
    Just got a second hand set of wheels with m/t's on. Taken off the factory wheel and fitted the new one and the wheel centre sits much prouder than before and doesnt look right.
    Is it a different offset? Do I need spacers?
    Not that I'm a newbie at all. ahem
    Nowt to do with offset. The reason is your new wheel is steel and so thinner than an alloy. Thats why the hub sticks out further. The offset is a measure of how far the centre of the width of the rim is from the mounting flats measured horizontally.
      soooo.... they are ok to fit?
        Dunno without knowing the offset...
        Do they rub at all on full lock? How do they look? (ignoring the hub area)
        If they dont rub and dont stick out miles they should be OK.
          Damn it. Fitted one on the passenger side, pulled out of the drive and in full lock theres a squeaking rubbing noise.
          Got out and had a look and cant see where it's rubbing though.
          Think the guy I got them from had a 2" suspension lift, would this make the difference? They are the same size wheels as the a/ts I have now but as you say the wheels fit very differently.
          Could this be the excuse I need to get some 2" uprated springs??
            Sorry Paul, didn't think of anything like that
            My truck was actually in theory +4", or on the back anyway. I had it dropped after the tyres were removed but its still +2"
            Chris
            Signature stolen along with Surf...
              Have a look around the wheel, somewhere it should say the offset. It will be in the form of ET and then a number. Standard wheels are ET8.
              A suspension lift wont make any difference.
              What size are they tyres fitted and what size are on your old wheels?
                Hey Chris
                No worries at all, my fault I didnt think to ask
                Tried to call you earlier but couldn't get through.
                So are we thinking 2" should do it?
                Been wanting an excuse to raise it a bit
                Good to meet you the other day
                  might be rubbing the arb, check for a shiny or clean bit.
                  Alan
                    What you meant to say was 'ET -8' really wasn't it?
                    =SOLD UP!=
                      I am only 16 ET's out! What the fek does ET stand for anyway?
                        'cos he can't see over the steering wheel if he sits down
                          All I can find on the wheels is Mangels T-7JJx15-435
                          The tyres are 31x10.5x15 which is the same size as the a/ts I have on the standard wheels
                            The difference in offset isnt great enough that it should cause issues.
                            Get your wife/partner/spose/neighbour/local samaritan to jump in your truck an pull it on full lock an then just have a look around. Upper wishbone clearance should be fine! ARB should be fine! Wheel arch should be miles away! Im gunna throw out the fact that it could just be worn steering stops!
                            fingers crossed!
                              Gah! Just found this on another offset thread. really confused now
                              'Just to add to that, the 7JJ has nothing to do with the ofset its the rim shape for holding on the tyre. I didn't know that until recently, I thought is was the offset but it is something about the height, depth and shape of the lip around the wheel that holds on the tyre.'
                              Really confused now!
                              I'll try and fit the tyres again when I come back form the plains run and see where they are rubbing.
                              either that or I have a guinea pig stuck in my wheel arch?
                              thanks for help so far peeps
