Are your original wheels the standard alloy and if so is the offset -8? Measure each wheel (the original and the new one) from inside edge of rim to the hub face. Just lay a straight edge across the rim and measure down to hub from this. Be as accurate as you can. Note each measurement and post here. I will try to work out the difference in offset of the new rims.
Nev
Nev
