HI Guys
Since reading Ive had some oil leaking from the front of my truck, maybe a coincidence... I ive cleaned the breather on the front diff out, but its still leaking and its getting worse.
It smells really strong so i'm guessing its gearbox or diff oil....
Any ideas what its likely to be...
If you lie on your back under the truck and look up, its mostly collecting by the prop shaft - where it meets the flange for the front diff.
Obviously because its hitting the prop shaft its flicking the oil everywhere, but I wondered if their was a "common" seal / gasket that goes around that area...
Any one know?
Any one know?
