Does anyone run the proper coolant (red) from Toyota, was told when bought car its the only thing to put in cooling system, its very expensive especially if radiator leaking, if not what other coolant would you recommend.
Also the two fans under engine, what are they for and how can you check if they are working, there must be a switch somewhere on the engine but where to look who knows?????
Thanks for your responses to my earlier question re 3 core radiator, got one on order so hopefully will do trick, also have fitted trans cooler so hopefully the combination will stop truck getting hot when towing.
