Hello there. At some point over the next 12-18 months I'm thinking of buying a 4x4 for my house in Wales, which is at the end of a long, unsurfaced and rutted track through a wood, with a ford halfway along. The track is passable in a supermini but you get a clonk or two to the underside and it will slip and slide if you're not careful where you put it (and sometimes even when you are careful). Furthermore when there is heavy rain the ford is not passable in a normal car as it can get to 18" depth within an hour. Hence my desire for one car in the family with a decent wading depth and preferably 4x4 to cope with the treacherous sections of the track.
As reliability and comfort are the main criteria, Land Rovers and their ilk are out. I don't want a soft-roader as I am skeptical they could deal with the ford. Given a fairly tight budget the leading candidates are imported Surfs (3rd gen) and Land Cruisers (Prado). Ideally I would like the 4WD to be on all the time because every single trip we make will begin and end with the track, which is where we need the 4WD the most. It's quite possible that I or the missus would forget to switch off the 4WD once we get on public roads, so I want a vehicle that can take full-time 4WD without damage. As the local roads are narrow there is a lot of driving on slippery verges and many of our friends live down similary challenging tracks - again, permanent 4WD would be useful at such times.
This set of requirements sort of points to the Land Cruiser, but would the Surf be an option with 3G models? I know it has the centre diff and thus can be used on road in Hi 4WD but would having HI 4WD permanently engaged have a damaging effect on the mechanicals? Am I better off simply going for the LC - which looks to be more expensive for a similar age and mileage - and forgetting about the otherwise worthy Surf?
Any advice appreciated.
Suss
Suss
