electronic rust
  • electronic rust
    hey i got an electronic rust proofer on my surf and they work
    got it in 2000 with small a,ount of body rust and it hasnt grown so im rapt. i reccomend it.
    if you break it you buy it.
    In England we have electronic rust generators. At least turning the key in the Surf seems to make it spread at an amazing rate....
    Seriously, what is one of these things? Do you have a link or make or something?
      Towards the bottom of the page
      http://toyotasurf.asn.au/techsite/electrical.htm
      Another member of the 'A' team
        Has anyone got any experience of how effective these things are? Apart from the first post
        Without Surf And Unhappy
          I'm unconvinced to be honest.
          The write up reads like one of those diet pills ads.
          "These pills, when combined with exercise and reduced calorie intake will cause you to lose weight"
          So, this thing charges your cars bodywork like a big capacitor? Hmmm...
            Use zinc.
              2 weeks ago i used a spray bottle with old engine oil and parrafin in it, so easy just spraying around hard to reach bits, may need doing every couple of months but its good for the truck
                I believe they use these on ships
                Mark........
                Let taste be the enemy of art!
                  I always think with these miracle devices, turbonator being another, if it was that easy the manufacturers would do it from the factory.
                  Toot! Toot!
                    Mark........
                    Almost, On ships its impressed current cathodic protection, as well as a bit of current you also have sacrificial anodes fitted. I suppose the principal is the same.
                    Bogus
                    Сви можемо
                      Well, not quite. Ships sit in something very conductive, and it wouldn't be possible to build up a charge (like the capacitor they talk about) on the hull cos its effectively grounded permanently.
                      Yep, turbonators, fuel catalysts etc etc. Despite all of the heresay and Joe Public testimonials, scientifically, they dont hold water.
                        What about BobBoxes?
                          Hehe, fool the ECU into squirting in more fuel, get more power, thats all. No magic, no 'everything is brilliant'. An expensive, shiny 'ebay resistor chip' IMHO.
