Rear Window lift mechanism
  • Rear Window lift mechanism
    Hi all,
    I've recently purchased a 4 Runner, and sadly the rear window lift mechanism isn't too healthy. One of the nylon wheels that sit in the channel under the glass is shredded and one of the arms (the other one obviously) that connect into these nylon wheelsr has broken off. I've managed to effect a repair by pairing the working arm with the ok nylon wheel, and patched with other arm with nuts bolts, washers and the shredded wheel. Does anybody know if you can get replacement runners, or indeed create a new one with a nylon wheel and a nut and bolt from something else?
    Originally posted by rjm67
    Hi all,
    put an add in the parts wanted section and you will be able to get the complete mechanism at reasonable cost
      Thanks for that, much appreciated and I shall do, but I was wondering if anybody had an alternatives that might provide a simpler fix.
        http://www.toyotahilux.com/?doc=16&cid=717&vid=906
